Sweep object and proboolean mapping problems
  • Sweep object and proboolean mapping problems
    I sweep a simple rectangular object along a path and generate World UVW mapping on the fly. This creates the correct mapping for the object as I want.
    When I run a proboolean subtraction on the object to remove some cutouts, the mapping is lost.
    How can I keep the UVW mapping from the original sweep object?
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    Try collapsing it after the sweep and then do the boolean.
      I'll give it a go - thanks for the tip.
      Kind Regards,
      Richard Birket
        Just tried that and it makes no difference. Any other ideas?
        Kind Regards,
        Richard Birket
          Right, I seem to have solved it and the answer is: Don't Use Probooleans.!!!!! This is the first time I've bothered with it and it doesn't work properly - great!
          Kind Regards,
          Richard Birket
