How can I make the helix have more segments to then have a better curve? I'm seeing it too faceted. I'm able to add more vertexes, but that does not help the curve? Thanks.
helix in max
use a plugin called optimize spline.
http://www.maxplugins.de/
It will get rid of most of the vertices and smooth out the spline.
I use it all the time on stairs.
Geoff
hi,
select all segments of the spline and rightclick-> change Line to curve. Then you should be fine and optimize spline should work as expected.
Dieter--------
visit my developer blog
Maxplugins has a object called spiral that has a function for setting the number of steps in the helix.
http://www.vg2max.spb.ru/Spiral.htm
"Spiral is a new parametric shape object similar to the standard Helix object. However, in contrast to Helix, it is based on the Gold (Archimedes' Spiral) or Logarithm (distance between turns is not equal) algorithm and the user can control the number of vertices."
