When one tries to achieve the kind of accuracy we are used to with VRay, it falls apart (literally: oversample and it crashes.).
Long live hardware-independent raytracers, thanks a lot.
Edit: from the demo i had, it seems they moved it from GPUs to CPUs.
The issues remain, though.
Check in the aerospace gallery image 4 and 7.
Where sharp corners meet (fuselage and top compartments in number 4, vertical panles and ground in 7) you will notice streaks.
I could not let them go away, no matter how hard i tried.
It seems to be due to shadows and GI sampling.
Raising the quality kills the app, memory-wise, and leads to crashes. EVERY time.
nono, they had a demo a while back (three months or so?).
I simply tried it on the models of a chair and few other small demo things they had.
Still, the contact GI shadows were bad, and streaked, exhibiting the issues you can see in the aerospace images (which i checked because of your post ).
I have no idea where they got the models from, tbh.
the default image as i load it and let it render (quickly by all means!). no matter how much i let it refine, it won't clean up those issues through the interactive renderer.
so i turn to the final renderer, after having upped the shadow quality for the interactive one.
with these settings, this i s what i get on xp 64 with 2 gb of ram:
And this:
and finally this. Notice how upping the shadow quality in the interactive renderer only leads to smaller "dots", not to a better interpolation (as seen in the zoomed bit).
As i said previously, it sure is quick.
As i said WRONGLY before, it's CPU, NOT GPU based.
Do not pretend VRay's flexibility or precision from it yet, though.
