What type of work do you use these settings with? I.e - Architecture, product design, etc?
I've been asked a lot recently about how to import architects models from Rhino, and I've never really settled on a technique. and minimum edge length 0.1mm sounds a pretty tight tolerance ...especially when architects seem to work on tolerances around +/-10m
Absolutely NPower Rhino-to-Max is the way to go. It opens the Rhino file as a native Brep. It also creates a mesh at render time so that each poly is max 1/2 pixel which is exactly what you always want. David Gill is very helpful there as well.
