script for export of panoramas as sphere-immages ?
  • script for export of panoramas as sphere-immages ?
    Hi i wanted to render out an animated sky out of max, with the panorama tool, to be able to use it later in animations, for animated clouds and so on.
    works fine so far, but the problem is, the panoramaexporter only renders out one single frame , so i would have to do frame by frame manualy.
    Does anyone of you know a workaround ?
    any script arround ?
    Tom
    eh.. vray render - camera properties -> change to spherical / fov = 360 and then render it as animation ..frame 0 to whatever
    www.cgtechniques.com | http://www.hdrlabs.com - home of hdri knowledge
      Hi Dschaga...
      Thanks...
      but i am not using vray for this... shame on me or rather on eon-software, cause vue-xstream that i need for this only supports mentalray..
      buuuuhhhh
      It would be great to see vray integrated to vue6 ore other way round...
      Tom
        ... then use mr lens shader mapchannel in render rollout with the map "wraparound"
          ähh...
          ok never heard of anything like this (dont use mr usualy..)
          but ill take a look
          Tom
          many thanks
            Hi Dschaga
            i am allways surprised what a great knowledgebase this is.. many thanks.. it works..
            only thing, what sort of unwrap does this produce ? is it a spherical unwrap or a cylindrical or a shrink wrap ?
