DivX Pains
  • DivX Pains
    Hi Guys,
    Does anyone have any advice about creating DivX files. I have an animation I would like to play on a DivX compatible DVD player connected to a Widescreen TV. I have created several different video files AVI, Quicktimes, everything, (without audio) but non of them will run through the DivX Convertor without errors. (5022) to be precise. I have looked at Virtual Dub but I cant find any kind of option to save out for DivX.
    I am running Windows Vista 64 which I am suspecting could be the problem...
    Daniel
    www.danieljhatton.com
    in virtual dub, under video/compression you can choose divx.
    but you also have to check the resolution is playable on you player/tv.
      Virtual Dub 1.7.6 - Joost. Thanks for the help. I cant actually see DivX displayed in the list. Is there something I have to do to ensure it appears in the list?
      Also, on another note. I am looking at the Video Post option in Studio Max and choose open Sequence but its asking for VPX files? I have a jpeg sequence from 0 - 1000.
      You can probebly tell I am very new to messing with video files/formats.
      Thanks!
      Daniel
        Ah. Dont download the Virtual Dub Version for 64x. It does not have the option for some bizaar reason..
        Daniel
          Ok, lol, new error. this has to be a Vista 64 problem....or..i'm stupid. When saving the AVI in Virtual Dub the following error occurs:-
          "Unable to initialize the output codec. Check that the video codec is compatible with the output video frame size and that the settings are correct, or try a different one."
          Daniel
            I dont know if you need a special 64bit decoder, but you can check on http://www.free-codecs.com/ you have to install the codec.
            I would recomend Xvid instead of Divx also.
            i do know that virtual dub has a special 64 bit version.
            as a side note; it would be better to output your sequence as png or tga, those are lossless, so you don't compress your output twice, with possible loss of quality.
              ok. after many hours of working out why I could'nt create simple DivX files I came to my conclusion. I can't generate a DivX file with size set to 750px wide. It was fine when it was changed to 624 x 352px. It seems there must be a pixel limit to divx. I did'nt know. : ) And the information is not readily available. Jees...am I a novice??
              Daniel
                I can't remember how DivX behaves, but some compression codecs wants size to be multiples of 8.
                Jonas Andersen
                Cadpeople | Visual Communication
                www.cadpeople.com
                  divx is crap. Best to use xvid as already mentioned. You want koepi's version. Just google it.
                  Yes I believe divx has some restrictions.. i cant recall if xvid does but I dont believe so.
