displacement
  • displacement
    can someone explain how to use displacement, normal, and bumps maps together. I guess displacement would be in the v-ray displacementmod and the bump in max's bump slot, but what about the normal map
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Normal maps go into the bump slot as well.
      You can set the bump slot to 'Normal Bump' and then use a bump and a normal map at the same time.
        bump
        How would you have two maps in the same slot?
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          If you use the "Normal Bump" map there's a slot for "Addtional Bump". Put your regular bump map there.
            Bump
            It is true.... all the smart guys are from Chicago! Thanks.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
