Installing render nodes 3dsmax2008
  • Installing render nodes 3dsmax2008
    Hello everyone, can anyone help me on a question?
    Im installing the new 3dsmax2008 , we have 2 standalone licenses, when installing the renders nodes, how do i license them?
    I started by authorizing everyone and at the end of 6 I received a message saying that i could no longer get a aut.code.
    if that is not the way to aut. render nodes can please anyone tell me the way?
    Thanks
    João Grilo, DreamLab Portugal
    Johnny Grilo
    http://www.square-zero-one.com/
    https://www.facebook.com/squarezeroone
    If you choose the "Render slave" installation mode, at the end of the installation you will be prompted to enter the IP address of the machine where the license server is running with the dongle; this must be configured correctly for the render slaves to work.
    Another way to change this setting is from the Start menu > Programs > Chaos Group > V-Ray for 3ds Max > Licensing > Administration > Change V-Ray client license settings.
      Thanks,
      i was asking the question for the 3dsmax 2008 software only, but it also helped because we also need to install vray!
      Thanks again.
      João Grilo
      Dreamlab
      Johnny Grilo
        For the Render nodes you don't have to authorize them. Just install Max and make sure you have all plugins installed as well (so the configuration is the same as the workstation) and you're done.
        www.artbyarjan.com - Online portfolio (temporarily offline)
        @home:
        / AMD Phenom X4 @ 3.00Ghz / ATI HD 4890 / 8Gb Ram /
        / Vista Ultimate x64 / Max 2010 / Vray 1.5 SP3a Edu /
        @work:
        / Intel Core2Quad Q9450 @ 2.66Ghz /
        Nvidia Quadro FX 3700 / 8Gb Ram /
        / Vista Bussines x64 /
          Thanks !
          joao grilo
          dreamlab
          Johnny Grilo
            Só tens que autorizar as 2 workstation's onde tens as licenças para trabalhar... tudo o que é rendernode, nem sequer arranques com o Max... agora sempre que quiseres instalar essas licenças, noutra máquina, vais ter que pedir um código á Autodesk... mas também, eles andam todos baralhados com os codigos... a mim mandaram-me um código e a máquina focou com o SN 000-000000 !!!!!!
            Nicolau Pais www.id3d.pt
            My current hardware setup: HP Z820 32-Core Dual E5-2670 128GB RAM - NVIDIA® RTX 3060
