Another "New system" post...
  • Another "New system" post...
    Hi there people, sorry if this is posted before but i could not find a matching one.
    i'm planning to buy a new comp for personal use. but also i would like to do some 3D.
    i'm pretty sure i'm going for the Q6600 processor, price quality seems very nice from what i have read.
    The videocard i think i'm going for an asus8800 GT 512mb. but also i'm not sure about this.
    now the motherboard is not sure, there is much choice and i dunno realy what the pro's and cons are. i'm going for an asus btw.
    the ones i have seen are for example:
    asus Striker Extreme (supports SLI, 680I chipset) most expensive
    asus P5K-E wifi (P35 chipset) cheapest
    i realy don't know and cannot find what the difference is, perhaps any1 can shed some light on this?
    say if i go for the P5k-E can i thow in all ddr2 memory? or do i have to get a specific speed ?
    any recommandations would be very welcome.
    mant thanks in advance!
    My Homepage : http://www.pixelstudio.nl
    have this at home
    ive got this setup at home
    not bad for max - the workstations at work make it look sad though, but hey for less than $2k Aussie dollaroos its great.
    im using the asus p5k deluxe wireless, q6600, 800 ddr2 with 5-5-5-15 CAS
    8gb ram in vista ultimate 64bit
    the gt8800 is great value and storms in max - no quadro $hite for me
    bios is great for overlocking, just maker sure you get matched ram
    ive got the zalman 9600 and can run @ 3.2 on air no probs rendering all night
    3.4 im a bit worried about motherboard temps but ive no front van, only cpu and case fan.
    hope this helps
      Ahh okey, many thanks for the info!
      my mind is a bit more clear now
        after reading all specs of the p5k-deluxe it seems it supports ddr3 memory. but i also see this is much more expensive then ddr2. is this worth the money?
        or should i look at the mobo that support ddr2 ?
          from what i read ddr3 has no real performance benefits yet and its waay more expensive
          id stick with ddr2
          if you go 8gb i think you are limited to 800 speed, havent heard of anyone getting more then 800mhz and +4gb to work
            would you also know if i for example on this motherboard (p5k-deluxe) can use ddr2 memory?
            the specs says it support ddr3 but no info if i could use ddr2 also ?
