Normal map map
  • Normal map map
    Has anyone ever seen (or can anyone make) a 3ds map that can convert another map into a normal map on the fly? Would be nice to be able to use tiles or other procedural maps as normal maps without having to convert into a bitmap or do a normal map render.
    Doesn't sound like it would be too difficult to create at least.
    No, it's not difficult at all actually... not sure if someone has not written one already.
      Well everyone? Is anyone up for the challenge?
        Well.. in general there shouldn´t be a difference when rendering a tiles map as standard bump map or you convert it to a normal map. The result should be the same.
        It would only give you an advantage if you intend to use it with the Relief Mapping Plugin.
          Exactly my intention
            relief mapping plugin? Do tell...
            Colin Senner
              Relief mapping (parallax mapping) is a pixel shader that uses a displace map and a normal map to create the illusion of depth. Think of it as a very light weight alternative to per pixel displacement. It was made for use with realtime 3d so it's adds almost nothing to the rendertime and creates a very realistic displacement.
              You can find the free map and utilities here:
              http://maxplugins.de/max2008_32.php?...ef&sort=Author
              Anyway the only problem with it is that it needs both a displace and normal map and you can only make displace maps procedurally in Max at the moment. Meaning if you want to use the Tiles map or another one you would have to turn it into a bitmap and use an external program to make the normal map (which would defy the whole point of procedural maps) or apply the map as a regular per pixel displacement effect and render out the normal map that way (which would take even longer)
              Having a map that could turn any procedural map into a normal map would make it a lot more efficient.
                So you can try this one and see if it works:
                http://www.spot3d.com/vray/misc/vraybump2normal.rar
                  Works great! You rock Vlado!!
                  The material editor preview sometimes turns pink but it still renders properly.
                    can you show an example of its use? or maybe a small test file?
                      I've been using CrazyBump to manually convert some of mine to normals. it works pretty smoothly with lots of control and a realtime preview
                      Dave Buchhofer. // Vsaiwrk
                        Unbeatable support! Wow.
                        A.
                        credit for avatar goes here
                          Here's a test I did. All images were rendered with the same GI/image sample setup. Only the material was swapped.
                          Only diffuse channel: http://www.ascantica.com/stuff/relief- no depth.jpg
                          Bump mapping: http://www.ascantica.com/stuff/relief- bump mapping.jpg
                          Normal mapping: http://www.ascantica.com/stuff/relie...al mapping.jpg
                          Relief mapping: http://www.ascantica.com/stuff/relie...ef mapping.jpg
                          Displacement mapping: http://www.ascantica.com/stuff/relie...ce mapping.jpg
                          In this test scene displacement mapping is actually faster then relief mapping, but the displacement adds a lot to the GI calculation. Caching it without any displacement beforehand gave these results:
                          Displacement mapping: http://www.ascantica.com/stuff/relie...g-cachedGI.jpg
                          Relief mapping: http://www.ascantica.com/stuff/relie...g-cachedGI.jpg
                          Max file: http://www.ascantica.com/stuff/relief.max
                          (needs Vlado's bump2normal map and the relief mapping v1.8 plugin.)
                          ~Shima
                            Great stuff. I particularly like the relief mapping.
                            Vlado, any way you can update the bump2normal map plugin to work for 2008 x64? I tried it just now and it doesn't...
                            "Why can't I build a dirigible with my mind?"
                            • #15
                              Works for me; what happens when you try it?
