network render settings save location
  • network render settings save location
    I posted this on the Area. Thought I might try on a better forum :
    When I render to network, Max 2008 creates a network folder in the destination folder for the renderings. If it doesn’t see this folder it returns to default values.
    I don’t care about saving my renders settings per job, and I want it to write to C:\3dsMax2008\Network, so that it remembers the settings from the previous job, and will be overwritten by any new jobs. It worked this way in Max 8, but there is no network option in the user or system path config in Max 2008. I assume the relative file path is in an INI or config file somewhere, but I can't find it. Any ideas? Thanks in advance.
    "Why can't I build a dirigible with my mind?"
