Hello all,
I've written a new script that might be valuable to you all! It's called Find CoInstances. I am looking for ways to improve it and if you like it add a point to my scriptspot so I can catch up with Lele
Find CoInstances works in two ways:
1. With Multiple Objects selected it will find objects that are cloned on top of each other resulting in animation flickering
2. With a Single object selected it will find and select faces that are coplanar
To select all faces which are coplanar use the list-box to "Select All", or
To select only those faces which are copies of the original, use "Select Only Duplicates"
Installation/Notes:
1. Run script
2. In Max goto "Customize->Customize User Interface...->Toolbars tab->Category: ColinScripts" and drag "Find Coinstances" to a toolbar, click to run.
Here is the scriptspot link, but I'll link it here as well!
http://www.scriptspot.com/3ds-max/find-coinstances
Download FindCoinstances1.00.ms
Hope this helps,
Colin
Installation/Notes:
1. Run script
Hope this helps,
Colin
