Probably something very simple, but cannot figure it out. I'm applying the mocap data files to the axyz people. Some of the files are very short, like walking down a stair, and need to be looped. though, I cannot figure out how to loop it??? Can anyone help me out! thanks!
looping mocap data
Sorry about that. I was not in front of my workstation.
Assign a Linear Float controller to the Playback frame. Create a key for frame 0 with a value of 0 and a key at the end of your playback length with a value of the same.
If your pointcache is 327 frames long, set a key at 0 with value 0 and a key at frame 327 with a value of 327.
You may have to adjust the start frame to get your loop to work correctly if you didn't account for this in the original animation. if your first and last frames are exactly the same then you need to remove one of them on playback so that the loop plays smoothly.
Thanks for your help. I did exactly as you said and the animation plays but without any loop to it? the curve editor shows the dotted line of the out range area....but no loop. I do not get it? though, I found another way to loop it with motion flow tools. A bit complicated but works. thanks again!
