Help with scissor wiring please
  • Help with scissor wiring please
    I'm trying to get a simple scissor with box wired together but I am a novice to this. Can anyone give me some guidance please?
    / these two lines need to fold together and apart when I move the box at the bottom
    l - box to move up and down
    This is for a pull out media cabinet wiring harness and for the life of me I can't get this to work. Any help would be greatly appreciated.
    The scissor part is easy it's when I attach the box to move the scissors that I have problems.
    Max uses Radians instead of degrees so you need to convert them.
    When you wire them use radtodeg(value) and add a minus to the value for the other peace of the siccors so it rotates oppsite way.
    Resolution Digital
    www.resolutiondigital.co.uk
      You could try using look at controllers too.
