Custom material editor scene
  • Custom material editor scene
    The scene is based on http://www.vray-materials.de/ and I decide to use it straight in 3dsmax material editor. I hope u like it, enyone who is interested just PM me.. ill upload the scene so everone who want to be able to use it.. now a little screens to show what I talk about
    Andrian
    _____________________________________
    www.fekta.eu
    Portfolio
    CG Talk
    thats pretty cool! Does it preview with nice speed? I like it so far!
    Kind Regards,
    Morne
      really cool stuff
      Martin
      http://www.pixelbox.cz
        I assume you can easily switch between the custom scene/box/sphere?
        Is there much of a speed decrease for that particular scene?
        Count me in as interested.
          yep, the speed depends of the complexity of the material u use ,and its quite fast, there is two lamps in scene so can be really slow some times, and u can add more than 1 material, like lightmat, Ill try to make more scenes to be used in diferent situation like light measurment, dispacement previews, but i really have to find more free time
          Instalation its so simple, ill try to be more specifick. Just put somewhere the scene with all contents (maps and max file) then u have to go into the material editor options like in the picture.
          example : let say u copy the scene in c:\mydocs\3dsmax\samplescene
          then u go to material options and follow the steps.
          Step 1 : first open the scene that u just copy in C:\mydocs\3dsmax\samplescene\maxtest.max,
          Step 2: load camera and light is a must to have lightning i made there.
          Step 3: is not necessary, do it if u want to have custom backgound in mat slot, its old kitchen HDRI.
          Step 4 : press ok or apply and ok u choose..
          Step 5: now u must choose the custom scene that u pick
          Step 6: load the custom material and save it in your library to have fast acess to it, then load it into mat slot, if there is allready material that u are working on max will ask u "Discard old material: and "Keep old material as sub material?" well u have to choose second one.. scene is useless with multy/sub materials.
          And u are set.
          As u can see in picture 1 there is a custom material loaded into the slot, first material is the material u are working on, the last material is the base plane., other material u can customize as well..
          Scene work without custom material as well..
          Have fun with it like me, and soon will update scenes with light room one, and displacement test plane.. feel free to help me like customize, add some more details or make new scenes...
          Andrian
          www.fekta.eu
          Portfolio
          CG Talk
            btw check ur PM..
            Andrian
            www.fekta.eu
            Portfolio
            CG Talk
              post some screens too, and feel free to ask...
              Andrian
              www.fekta.eu
              Portfolio
              CG Talk
                cubiclegangster: I assume you can easily switch between the custom scene/box/sphere?
                yep u can switch easily : Step 5.
                Andrian
                www.fekta.eu
                Portfolio
                CG Talk
                  Ahh, we dont have vray IES...
                  I've got it all set up other than that though, i'll just go replace those in your scene with normal vray lights when i've got time.
                  Thanks!
                    Thanks!
                    ah, yes, initaly i have used vray lights, but then i decide to use IES light, its kind of render fast in this scene.. i can provide u with the old version, but render prety slow... u decide...
                    Andrian
                    www.fekta.eu
                    Portfolio
                    CG Talk
                      Sounds like fun. I'd like to try it out
                        Cool!
                        I would like to try it too!
                        Preisler
                        Preisler
                        www.3dpixel.dk
                        www.linkedin.com/in/3dpixel
