Max Service Pack 1 available
  • Max Service Pack 1 available
    Just in case you didn't know, there is service pack available for Max (both flavours) on the support pages of the AutoDesk web site.
    got a direct link?
      http://usa.autodesk.com/adsk/servlet...inkID=10381720
      and
      http://usa.autodesk.com/adsk/servlet...linkID=9241178
        thank you!
          Nowt interesting in there then.
          Kind Regards,
          Richard Birket
          http://www.blinkimage.com
            Anyone else getting this beauty of a message when trying to install SP1"
            If I try to run the MSI instead of the Install.exe, I get:
              i believe someone from our florida office said if you do a network install of max 2009, this service pack will cause issues.
                gotta love this one:
                Performance
                A viewport performance issue related to the ViewCube has been resolved.
                Dmitry Vinnik
                Silhouette Images Inc.
                ShowReel:
                  Apparently, installing SP1 will switch any Network Licensed install of 2009 to a stand alone and give you the 30 trial period in which to activate. Looks like a registry hack will fix it...
                  http://area.autodesk.com/index.php/f...wthread/13704/
                    I had a similar warning pop up, after that I discovered that max 2009 and max design have two different SP1
                    dowloaded the right one and everything works fine
                    Alessandro
                      I just got a message from mu reseller that there are apparently some issues with the Service Packs. They adviced to not install them yet, in case you haven't done so...
                      www.artbyarjan.com - Online portfolio (temporarily offline)
                      @home:
                      / AMD Phenom X4 @ 3.00Ghz / ATI HD 4890 / 8Gb Ram /
                      / Vista Ultimate x64 / Max 2010 / Vray 1.5 SP3a Edu /
                      @work:
                      / Intel Core2Quad Q9450 @ 2.66Ghz /
                      Nvidia Quadro FX 3700 / 8Gb Ram /
                      / Vista Bussines x64 /
                        I looked for a different one. Did I blindly miss the link to the Design SP1?
                          here is the link for max design SP1
                          Alessandro
                            yes thank you zeronove. I did go and find it after you mentioned it. One would think that there would be a warning or a link to the design version...
                            The screwy thing is that the Hotfixes installed with no problems... I hope that doesn't mess anything up.
                            • #15
                              Originally posted by DrJan View Post
                              I just got a message from my reseller that there are apparently some issues with the Service Packs. They adviced to not install them yet, in case you haven't done so...
                              One of the issues is while working with light instances, you can't use the light lister anymore.
                              This is a direct quote from my reseller and it's all I know.
                              @home:
                              @work:
