At some point, I replaced these xref'd trees materials with a flat grey material, but i'm unsure of how to undo this. If I strip the material off it just leaves them material-less.. How do I restore the xref materials?
Restoring Xref material?
If the materials in your base xref model are intact, you can easily re-apply them in the main scene by opening the xref diaolg window and selecting the xref in question. Right click it's alias in the lower portion and select the option that sounds something like 'Apply xref materials to xref object.' (Sorry not in front of MAX at the moment to verify the exact name) Hope this helps if I interpreted your question correctly!
Cheers,
Dave
