I have been struggling with snaps for ages so I thought I would post here. I can grab my ucs stick and move things along the x,y, or z just fine. I can grab the box of the ucs icon and move things freely. The problem I am having is when I turn my snap on, enable my constraints, grab the ucs, the constraint sometimes work and sometimes doesn't. I fight with this all the time. Am I doing something wrong? Does this make sense?
Snap
Snap
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
what helps is locking the selection with the space bar, then the snap finds the right object...Marc Lorenz
___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
www.marclorenz.com
www.facebook.com/marclorenzvisualization
Snaps
If nobody else is fighting this then Imust still be missing something. Here is my screen
http://www.whitebirchstudios.com/pub...naps/snaps.htmBobby Parker
phone: 2188206812
- Windows 11 Pro
Thanks Jacob,
I see what he/she is doing, but the issue is when I pick the x it'll turn to the y by itself. I'll try playing with the 2d snap, but it usually happens when I am in perspective. I'll try the shift as well. This has to cost me hours a week.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Snap
Clifton, holding down the shift will just make a copy.Bobby Parker
phone: 2188206812
- Windows 11 Pro
No, not while drawing a line.
I guess you are modifying an existing spline in the video though. In the case shown in your video, make sure axis constraints are enabled, x-axis constraint is on, endpoint snap is on, select the desired vertex, click to line endpoint, move along x-axis and select the endpoint below which you are squaring up to. Do not use the UCS arrow things, you can't use snap in conjuntion with those.
Oh, also, don't use 2d snap. It only works if everything is perfectly in the zero plane. Use 2.5d for line work.
I'm not sure why this isn't working for you. I perform dozens of similar snap operations daily.Last edited by Clifton Santiago; 04-09-2008, 02:43 AM."Why can't I build a dirigible with my mind?"
The F5, F6, F7 seems to solve my issue. I do get that rubber band effect and it moves slow.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Well, I'm glad that works for you, but its the same as using your axis constraints buttons which you were already using. You can turn off the rubber band, which I do immediately after installing max. What noob programmer thought that was a good idea?"Why can't I build a dirigible with my mind?"
The 'issues' with snapping in Max are one of the reasons I much prefer to do my 3d modelling in Autocad and file link into Max. I know there are some things that are quicker in Max, but on balance, I prefer the robustness of typing '.xy', '.x of this but .y of that' etc within Autocad.Kind Regards,
Richard Birket
http://www.blinkimage.com
