rotate in PS
  • rotate in PS
    Isnt there a command to rotate something to a certain angle....Perhaps picking something in your PS file to align to? I cant find it anywhere and I swore it was somewhere. I have a layer that is like a banner at an angle and I am creating text and stuff that I want at the same angle. I know I could just write it down.... but I forgot and I could eyeball....Just for future reference.
    Thanx all
    Eric Camper
    Studio 3D
    www.dbfinc.com/studio3d
    Rotate
    If you hold your shift key down it'll incrementally rotate. or you could type in your angle.. up on your menu you'll see that option when you are in your rotate command.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      In free transform mode up in the tool settings there is an angle type-in
      Eric Boer
      Dev
        Glorybound beat me
        Eric Boer
        Dev
          image or transform /rotate/arbitrary
          You can also use "transform again" (ctl-shift-T) to apply the same transform successively to different parts.
          b
          Brett Simms
          www.heavyartillery.com
          e: brett@heavyartillery.com
            PS
            Hijack! I have always wondered why when I cut/paste a part of an image into another image of the same size it doesn't come in at the same place. Example would be when I do a render matte pass and I paste that matte into the scene it always comes in high. It isn't a problem moving it down, but why do I have to? Any clues?
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              That is a pain, but you can get around that (and get around using up excess RAM with your clipboard) by floating your selection as a layer and duplicating the layer across through the menus instead of doing cut/paste. Then it will come into the new file in the correct position.
              b
              Brett Simms
                DOH....NO....hehe...I know that guys...LOL... I thought there was a command to ALIGN something to something. Like have a line at a certain angle and then rotate it to match or something...but maybe I dreamt it.
                Eric Camper
                Studio 3D
                  @Glorybound
                  If they have the same size, then ctrl+shift when drag and drop from one image to another.
                  Preisler
                  Preisler
                  www.3dpixel.dk
                  www.linkedin.com/in/3dpixel
                    You just need to hold shift when you are dragging from one image to the next. Then yes, if they are the same dimensions it will come in at the same place.
                    Tim Nelson
                    timnelson3d.com
                      Eric, first set the ruler tool, then with the right layer selected go to transform->rotate it will automatically inherit the rotation from the ruler.
                      www.suurland.com
                      www.cg-source.com
                      www.hdri-locations.com
                        hmmm Ruler Tool? CS3?
                        side note, my Adobe help center thing is jacked. When I go to help from PS, I get the help for Indesign or Premiere...
                          @jonahhawk
                          It´s under the rollout with the eyedropper tool.
                          Preisler
                          Preisler
                          www.3dpixel.dk
                            Nice! I sure wish I could get the help system to work. VRay forum is more informative anyway.
                            • #15
                              There it is!!! Thanx dude..
                              Eric Camper
                              Studio 3D
