Scripted Billboard people generator
  • Scripted Billboard people generator
    posted here as a response to this thread:
    Works on a folder full of images with alpha channels. Keeps the proportion. Makes all the billboards the same height...
    Code:
    -- simple Scripted Billboard creator. Operates on a folder full of images. Will add an interface and variables, saved paths etc later. Suggestions welcome jonahhawk at hotmail.com.
    files = getFiles "\\\\server\\path\\*.tif" --edit this to match the path to your images.
        for f = 1 to files.count do
                theMap = openBitMap files[f]
                theMap.filename = files[f]
                    -- Get the ratio of the bitmap and set the length and width acordingly
                        local planeRatio = (theMap.width as float)/(theMap.height as float)
                        local theLength = 68 --This is the height of the billboards... all of them. will add randomness maybe...
                        local theWidth = theLength*PlaneRatio
                    --Set naming
                        local refPlaneName = (getFilenameFile theMap.filename)
                    --build material
                        local matName = (getFilenameFile theMap.filename)
                        local theMaterial = VRayMtl()
                        theMaterial.name = refPlaneName
                        theMaterial.texmap_diffuse = Bitmaptexture fileName:theMap.filename
                        theMaterial.texmap_diffuse.name = (refPlaneName + "_Diffuse")
                        theMaterial.texmap_diffuse.coords.blur = 0.01
                        theMaterial.texmap_opacity = Bitmaptexture fileName:theMap.filename
                        theMaterial.texmap_opacity.name = (refPlaneName + "_Opacity")
                        theMaterial.texmap_opacity.rgboutput = 1
                        theMaterial.texmap_opacity.monooutput = 1
                        theMaterial.texmap_opacity.coords.blur = 0.01
                        showTextureMap theMaterial theMaterial.texmap_diffuse off
                    --build plane
                        local refPlane = plane name:refPlaneName length:theLength width:theWidth lsegs:1 wsegs:1 mapCoords:true
                        refplane.material = theMaterial
                        refplane.realWorldMapSize = off
                        refplane.lengthsegs = 1
                        refplane.widthsegs = 1
                    --position the plane
                        in coordsys (transmatrix refplane.transform.pos) refplane.rotation = (eulerangles -90 0 0)
                        ResetXForm refplane ; CollapseStack refplane
                        refplane.pivot = [(refplane.max.x+refplane.min.x)/2, refplane.min.y, refplane.min.z]
                        refplane.pos = [0,0,0]
                    --clean up
                    freescenebitmaps()
                    gc()
