Walking Away from an Image
  • Walking Away from an Image
    I'm curious about this. Do you ever walk away from an image after a few minutes then come back to it to see if it looks alright?
    Sometimes I find myself overtweaking an image post-process - so I force myself to take a break. Sometimes minutes or hours I will come back to it and it will look 'off/incorrect.'
    Do you guys experience the same thing? And if so, how do you normally go about solving this?
    LunarStudio Architectural Renderings
    HDRSource HDR & sIBL Libraries
    Lunarlog - LunarStudio and HDRSource Blog
    yep, i recognize that behaviour!
    I've also seen people flip the image on the horizontal in photoshop because you often notice things that aren't correct, and then flip it back..
    www.peterguthrie.net
    www.peterguthrie.net/blog/
    www.pg-skies.net/
      Another thing I do is print out images, or send them to my home computer. Then go home and have a few beers, and critique them. It helps figure out what is wrong with it.
        I used to do that ages ago.. then I gradually lost the habit.
        I don't walk away from images very often, at least not as often as I do when modeling something which is quite detailed and complicated.
          Do that all the time, and best thing is to sleep on it and look at it again the next day. I can be very happy with an image and then come back to it and think it's crap and continue working on it. I also often look at the monitor from 1-2 meters away.
          /Thomas
          www.suurland.com
          www.cg-source.com
          www.hdri-locations.com
            I do that a lot.
            And sometimes I try to look outside from window, to paintings on wall, have coffee and look at people's faces. And when back, sometimes I see that I messed the image ehehe.
            I also look at image 1-2m away from monitor too. SOmehow I see image better that way. And sometimes I need to choose between 2 different versions and it becomes funny to go away from monitor-look-go near monitor and change image- and walk back again ehehe
            I need a partner who can switch the images on my monitor when I am standing away or a remote
              Originally posted by giraffe View Post
              I do that a lot.
              A lot of image browser have a slide show feature, just put both images in a folder and let the show begin
              Eric Boer
              Dev
                My biggest problem is that I'm never statisfied with what I make.
                When I'm working on something, I think it looks good, but the next day I think it sucks and this keeps repeating itself, causing me to eventually loose interest in the image.
                That's why I have quite alot of unfinished projects on my HD :S
                www.artbyarjan.com - Online portfolio (temporarily offline)
                @home:
                / AMD Phenom X4 @ 3.00Ghz / ATI HD 4890 / 8Gb Ram /
                / Vista Ultimate x64 / Max 2010 / Vray 1.5 SP3a Edu /
                @work:
                / Intel Core2Quad Q9450 @ 2.66Ghz /
                Nvidia Quadro FX 3700 / 8Gb Ram /
                / Vista Bussines x64 /
                  I think it is a good habit to walk away and come back later to get a fresh perspective on an image. I also find showing it to someone else is really handy, because every time I show an image to someone who is not familiar with it I find that I very quickly spot my own mistakes. If it's a client you are almost guaranteed to spot them about 1/2 a second before they do
                  b
                  Brett Simms
                  www.heavyartillery.com
                  e: brett@heavyartillery.com
                    Squint
                    I find myself squinting at my images a lot. You can really tune into your focal point and see your lighting highlights well.
                    Bobby Parker
                    www.bobby-parker.com
                    e-mail: info@bobby-parker.com
                    phone: 2188206812
                    My current hardware setup:
                    • Ryzen 9 5900x CPU
                    • 128gb Vengeance RGB Pro RAM
                    • NVIDIA GeForce RTX 4090 X2
                    • ​Windows 11 Pro
