i7 Processors..any good ?
  • #61
    Originally posted by DVP3D View Post
    huh? you mean by having just 4 cores instead of "8" it is faster?
    The I7 is only 4 cores...hyperthreading just handles the data differently...doesnt it ?!
    Regards
    Steve
    My Portfolio
    • #62
      Originally posted by flino2004 View Post
      I have my i7920 running at 4.0Ghz stable with air cooling system (1795 RPM).
      my tests with prime95, I got 71C for CPU and 68-70C for cores
      Are there any tutorials you followed to overclock your cpu ?
      Regards
      Steve
      My Portfolio
      • #63
        i7
        Bought one recently for £1100 ready made as I couldn't source stuff to build my own any cheaper, i7 920, 6 gig mem, cheapish card, but it is awesomely fast without overclocking, approx ⅔ sometimes ¾ the speed of my work HP dual 2.6 Xeon (quad core each) which cost £3500.
        Being an Asus board it comes with oodles of O/C'ing applications, maybe not the ultimate but it works.
        laters
        spike
        • #64
          I followed this article
          http://www.bit-tech.net/hardware/cpu...-core-i7-920/1
          this was my first OC, I found this article and they are using the same memory speed that i have.
          if you have ASUS MoBo
          "We found that enabling the HPET (High Performance Event Timer), or as Asus label it, APCI 2, is critical for keeping the clocks on Core i7 CPUs accurate. Without it turned on, the multiplier jumps around crazily if we watch CPU-Z, but with it on, the multiplier reading is solid and the clock frequency only jitters very slightly according to fractional variations in the base clock"
          APCI 2 is under power (bios) some people that overclocked their i7 couldn't find this option.
          happy OC
          show me the money!!
          • #65
            we did some tests awhile back on the 920 and found some interesting results if anyone is interested. http://blog.renderstream.com/?p=92
            www.boxxtech.com
            • #66
              Yes it is this test I was thinking about which shows it is faster with hyperthreading on. Which is why I was suprised another user says the other way around.
              Kind Regards,
              Morne
              • #67
                any benchmarks to see how those i7s holding up with the amd phenom 2?
                Dmitry Vinnik
                Silhouette Images Inc.
                ShowReel:
                • #68
                  It compares more closely to the Core 2 Quad Q6600 it seems.
                  http://randomcontrol.com/index.php?o...=140&benchid=1
                  The real question is how much would it cost to build a Phenom II render node. Since you are looking at ~$1k US for an i7 node, it would need to cost well under $800 to recoup the ~20% loss in performance.
                  Ben Steinert
                  pb2ae.com
                  • #69
                    Originally posted by cecofuli View Post
                    CPU: DualXeon QuadCore E5440 2.83Ghz@3.25Ghz
                    I didn't realise the xeons were overclockable.
                    Still, even with them overclocked the i7 is better bang for buck.
                    Many Thanks
                    Patrick
                    • #70
                      in case it hasn't already been mentioned is a good reference for 3ds max cpu comparisions: http://www.tomshardware.com/charts/2...2009,1380.html
                      thats a good point bestee. another thing to consider that i think some people overlook is power consumption. the i7 is also very energy efficient. for example our high end render farm system has fourteen dual quad core blades in a 7U box. we also have a phenom 945 based render node. the phenom node draws 400 watts. the entire 14 dual quad core 7U box draws 1400 watts.
                      it will take 34.4 of the phenom nodes to equal the computational power of the 7U system. in other words, if you run the 7U system for 12 hours a day and assume 28 cents/kilowatt hour, you will spend about $141 to operate that system.
                      in contrast, if you run the 34.4 of the phenom nodes over the same time at the same rate you will spend about $1,390 to operate them.
                      this doesn't mean that the phenom node is a bad option. it just means that building a system like this is only cost effective up to X number of nodes. maybe 4-5 nodes i'd say. it all depends on what you are trying to accomplish with your farm.
                      -joe
                      www.boxxtech.com
                      • #71
                        Looks like OC 920 is about the same as our Dual 5520s without HT.
                        AUTHOR: moi
                        MACHINE: Dell T5500
                        Software: 3ds max 2009 - 64bit
                        Renderer: VRay 1.5 SP3
                        RAM: 24 GB
                        CPU TEMP : --
                        CPU THREAD : 8
                        CPU: Dual Xeon Nehalem E5520 2.27 Ghz HT OFF
                        RENDETIME: 16m 53sec
                        Same machine with HT ON
                        RENDETIME: 13m 15sec
                        • #72
                          Ok, this is strange. I just happened to turn off hyperthreading in the bios as I read somewhere that Arma 2 runs better. So I thought I'd try it for rendering too and have some suprising results.
                          I have a 940 on my main comp and i920's on my render nodes. On a particular scene I am rendering at the moment, using irr map and brute force, the i920's are both in at around the 2 minute mark, but the 940 is about 41 seconds...what the hell!!
                          Regards
                          Steve
                          My Portfolio
                          • #73
                            you probably have the lc set to 4 passes not 8?
                            WerT
                            www.dvstudios.com.au
                            • #74
                              I have always had my passes set to 12. My other render nodes still have hyperthreading on which splits each core into 2 threads.
                              Regards
                              Steve
                              My Portfolio
                              • #75
                                I have my i7's running at 3.8ghz on air cooling, they are not even hot, and only require a small voltage increase to get this speed? I've just read some earlier posts saying 4ghz required water cooling? Maybe that is an old stepping?
                                WerT
