At the moment, no you cant get a dual board for the i7's.
Computer Specs
Computer specs
OK. I am ready to plug on a machine. Simply:
Quad i7 - which one?
12 Gb of DDS3
What is the best video card for the money?Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Specs
How about the graphic card? Dual 512 ?Bobby Parker
phone: 2188206812
- Windows 11 Pro
SLI video only works on a single monitor as far as I know. You are probably better off going with a single upper tier DX10 gaming card for the best price/performance/versatility combination.
Photoshop makes good use of your video card since CS4, so don't go below 1GB if you use CS4 or plan on upgrading. Autodesk has been working on the DX support pretty heavily in Max with the last two iterations, so expect some performance/stability advances there also to make use of whatever video RAM is available on the card you choose.Ben Steinert
pb2ae.com
Video Card
How about the Radeon HD 4870X2 PCI Express, 2GB?Bobby Parker
phone: 2188206812
- Windows 11 Pro
I personally prefer Nvidia because I have had bad experience with every ATI card I have ever used. However, all of this was before AMD merged with ATI, and I have seen some good reviews of ATI's newer hardware.
My best advice would be to visit a few computer parts retailers(such as newegg), look up the cards you are interested in, and check out the customer reviews. Keep in mind that 50% of people will not review a product unless it has fared badly, so you are better off avoiding the worst reviews and looking at the ones that give a mediocre score. If the overall score from all reviews is really low, you would probably want to avoid that card.Ben Steinert
pb2ae.com
Just a quick note to prospective buyers:
I'm finding the i7 920's are running pretty hot, but it does depend a bit on which software you check with.
Idling along they are around 40-45 degrees, but rendering they are up at 75-85 as measured by Coretemp.exe
If I check with RealTemp then it's about 10 degrees lower across the board. From what I googled I think RealTemp is more accurate, but I still find they are too hot. I'm looking into other cooling options now.
This is just stock chips and cooling btw - no overclocking (not sure if they can be?) and an Antec case with a couple of basic fans.
b
Any suggestions for a cheap place to build an i7 in the UK?
I'm looking at speccing
i7 920
2 x GSkill 6GB 1333Mhz
Gigabyte EX58-UD3R
ATI 4850 1024Mb
Antec case with 550W psu
vista ultimate 64
HD + DVD drive
for under £1300Patrick Macdonald
Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
550W Power supply? No no no, too low for the power needs of your combined mobo+cpu and video card. min 750w... Most video cards now days require 2 sustained 12amp lines to the card, a 550w just won't have enough juice after powering the cpu. I know it sucks, but make sure you get a good quality power supply to provide your rig with enough sustained power to do the work you need done.
edit: check the power demands of the video card to make sure.Colin Senner
heh, fair enough, I thought even with serious components, alot of the time you rarely approach full load on most PSU's. CAD2 spec a similar workstation with just 670W.
Just trying to keep the costs down!Patrick Macdonald
