Any suggestions for a good bit of software for designing HTML websites? Ideally freeware/shareware/cheap and with a helping hand GUI rather than having to rely on pure HTML coding.
Recommendation for good free/share/cheap HTML web design software
Kind Regards,
Richard Birket
http://www.blinkimage.com
----------------------------------->Tags: None
I was looking some time ago for an HTML editor; I found one or two solutions but all of them were lacking and produced awful HTML code. I had to go back to my old Dreamweaver MX.
I'd be curious what other people are using too.
VladoLast edited by vlado; 14-01-2009, 12:31 AM.I only act like I know everything, Rogers.
nvu is said to b quite nice tho i never used it:
http://net2.com/nvu/index.html
On i really like myself is aptana:
http://www.aptana.com/studio
it's based on eclipse and i found it really nice.
Regards,
Thorsten
Cheers Thorsten - will check them out.Kind Regards,
Richard Birket
Still using dreamweaver but mainly for the site management and search / replace bits rather than the visual side of things - I'd normally use code view and css.
Free bit wise try http://kompozer.net/ and http://www.webon.comLast edited by joconnell; 13-01-2009, 08:15 AM.
I've used nvu and textpad, but then, my html needs aren't exactly high end shall we say.Dave Buchhofer. // Vsaiwrk
Do you also want a "WYSIWYG" interface? Where you can see what you've done?
Like joconnell I also use Dreamweaver for easy placing of elements (we have a license since I work for a webdeveloping company). Other than that I use wSciTE or Textpad.
You could try HTML-Kit or 1stPage 2006www.artbyarjan.com - Online portfolio (temporarily offline)
@home:
/ AMD Phenom X4 @ 3.00Ghz / ATI HD 4890 / 8Gb Ram /
/ Vista Ultimate x64 / Max 2010 / Vray 1.5 SP3a Edu /
@work:
/ Intel Core2Quad Q9450 @ 2.66Ghz / Nvidia Quadro FX 3700 / 8Gb Ram /
/ Vista Bussines x64 /
I've found our old copy of Dreamweaver MX. Seems like that's probably the best solution as I can use layers to generate the look of the site accuratly and then convert the layers to a table.Kind Regards,
Richard Birket
