How do I model this!!!!
  • How do I model this!!!!
    I hate doing this and I know I'm missing brain cells but do any of you have suggestions on the best way to model this light fitting. It's doing my head in. I tried creating a opacity map and simply mapping it onto a sphere but it didn't look very good (probably my unwrapping abilities).
    I'd like to model it but I can't work out how to do it best. I know I'm missing a trick. Anyone have any ideas??????
    Greg
    Not exactly sure, but one of the Soulburn scripts allows you to draw splines onto objects and it seemed to work pretty well on my tests. You could model a sphere and squiggle all over it, then use sweep on the squiggles!!!
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
      you don't have to model it
      here is my trick:
      use texture with vraydispalcement with water level
      2009max file with simple texture:
      http://rapidshare.com/files/211009040/d.zip.html
      to make it look more real you can make few layers of spheres with different texture and water level thickness.
      sticking out splines you can add extra on top manually
      good luck!
      Luke Szeflinski
      :: www.lukx.com cgi
        Or doing it the "Ansi" way :
        http://www.3delicious.de/spielwiese/...PFSplines1.htm
        :P
          Nice responses,
          tricky - Thanks that script looks brilliant, never used soulburn scripts before.
          Lukx - That is genious, still can't quite work out why it works, but it does.
          Instinct - I wish I spoke german, that looks great. When I have more time I'm going to try and go through that by the images. Never really played very much with particles before.
          Been doing this for 3-4 years and I still got sooooooooooo much to learn.
          Thanks again
          Greg
            sorry...my bad...here's the english version
            http://www.cgarena.com/freestuff/tut...nes/index.html
              No problem. Soulburn scripts are amazing. I'm using them more and more. Where in Scotland are you BTW?
              Kind Regards,
              Richard Birket
                Tricky - I'm in Edinburgh. Where are you?
                I work as the only visualiser for an Architects firm, which means I don't get the benifits of learning from others. (except you guys of course). Hence I seem to be missing a lot of tricks. The only scripts I have used are Lele's top notch Physical camera tricks. I just don't have the time to experiment & progress anymore. How do you guys do it?
                Thanks again.
                Greg
                  Ahh...Edinburgh. I love that city. Its been a while since I was up there though. I used to like looking around Jenners.
                  I'm down in Oxford and use this forum daily. It is very useful and full of intelligent, generous people. To be honest, we have only really started looking at scripts in the last 12 months or so. I have zero knowledge of writing them myself - I struggle enough with basic English, let alone Maxscript!
                  Kind Regards,
                  Richard Birket
                    i have used the PFlow way to model a similar light in the past.
                    It works well but the splines it creates are quite heavy, if you need to view it close up you might have to manually adjust some of the splines as they tend to interect
                    Chris Jackson
                    Shiftmedia
                    www.shiftmedia.sydney
                      I used to work for an architects firm in Edinburgh too. For too long in fact, my advice would be to quit and work for yourself then if you don't have any free time to experiment you're thankful rather than resentful!
                      www.peterguthrie.net
                      www.peterguthrie.net/blog/
                      www.pg-skies.net/
                        It's definetily beautiful today. The sun is shining and I'm going to go out to enjoy it.
                        tricky - " It is very useful and full of intelligent, generous people." -
                        I know, It's only thanks to the unselfish, kind & enlightened, people here that I have progressed as far as I have. I have not visited the forums much lately because of tight deadlines and such but am now going to make sure I am a regular once more.
                        Greg
                          Prunes for that mate!
                          Kind Regards,
                          Richard Birket
                            hello,
                            here it my tip:
                            you can use ivygenerator but dont assign any leaves.
                            check yout the result here:
                            http://graphics.uni-konstanz.de/~luft/ivy_generator/
                            if you play with its settings, youll get what you want in the end
                            Martin
                            http://www.pixelbox.cz
                            • #15
                              Like to see what IvyGen did, but the links seems bad?
                              b
                              Brett Simms
                              www.heavyartillery.com
                              e: brett@heavyartillery.com
