Projecting 3 movies with one computer
  • Projecting 3 movies with one computer
    Anyone have any experience or ideas on how to project 3 movies using 3 different projectors (1 movie per projector) from one computer. I need to play 3 movies that will need to match up on 3 separate walls and they need to be controlled by one computer. Would three graphics cards work? Not really sure where to begin with this one. I guess you could have a quicktime per monitor, but how do you start them all at once?
    Any ideas?
    Thanks
    This looks interesting, free if you set it up each time, probaly not too bad if you just want to display 3 streams at the same time http://www.troikatronix.com/isadora.html
    Eric Boer
    Dev
      Matrox have a solution to output three videosignals with one gfx card. ..they use a dual-dvi connection (which is normaly needed for 30" monitors) to split one signal into two signals.
      Have a look at VJ software and VJ forums if you need more informations, because this is the normal usage for such a setup
      www.cgtechniques.com | http://www.hdrlabs.com - home of hdri knowledge
