MAX 2010 - where is the render region button gone ?
  • MAX 2010 - where is the render region button gone ?
    hello all,
    quite self explanatory....wanna use maxes render region, not vrays, as that youne is quite slow to use...
    any ideas where i can find the goo old button?
    thanks a lot
    Martin
    http://www.pixelbox.cz
    You can find the controls in the Common tab of the Render Setup dialog (F10). I am not sure you can bring it to a toolbar as a button though.
      i am not sure you can bring it to a toolbar as a button though.
      vlado
      yes!! You can! :d:d:d:d
        any idea how? was trying it for abou half an hour but then i gave up.....where is it located in customize user interface???? maybe i just did not see it
        Martin
          In Max 2009, you can go to Customize-->Toolbars-->MainUI-->Render and add the "Edit Render Region" to any toolbar. Might be in a different place in 2010 though.
            nope not there (((
            Martin
              The "Edit Render Region" button is ok if you want to resize your render region but it is useless if you want to desactivate to render a full view.
              Maybe i'm wrong but it have to be another button to activate or deactivate the render region like in older versions of 3dsMax.
              www.gaell.com
                Quickly scanning this thread, I think you're looking for the "Area to Render" dropdown menu located on the Rendered Frame Window?
                That lets you choose View/Selected/Region/Crop/Blowup...
                Edit: Took the time to read the thread now, you want to customize it, not sure...
                Edit2: Not sure there is a preset custom option, but you could write your own MaxScript with setRenderType #region and put that anywhere you want...
                | LinkedIn | Twitter | JCanimator.com |
                  OK SnipeyX, thanks for your tips....ill have a go at it when i have some spare time
                  Martin
