Don't support xref'd objects including xref'd materials. This is awful and I have no idea why this limitation exists.
Heads up: 2010 containers
That's true, but i've been moving towards xref'd materials for a while now where I have a central library, and everything is xref'd from it. This limitation broke that in two! Now I have 8 villa types using the same materials that I have to make sure are updated because xref'ing doesn't work in containers, and xref'ing the objects doesn't work because each villas is several hundred items (and you can't instance xref scenes so the memory usage skyrockets).
