Using backburner multiple machine cores for single image
  • Using backburner multiple machine cores for single image
    Dear v-ray admins and users,
    This theme is slightly off topic, so I set it here. Can any of You please tell me how do I set up two or more machines to render single v-ray image? For example, one scene in 1600x1200 on i7 720 is being rendered for 2 hrs. Is there any way how can I boost computing power with the other machine? Machine specs are:
    #1
    os: Windows Vista Bussiness
    Max version: 2009 Design 64 bit
    Backburner version: all the same
    #2
    os: Windows XP Pro
    Max version: 2009 Design 32 bit
    Is it possible to cope these two machines and to make it render as one? There are 8 cores alltogether, but I can only use 4, because backburner is always only sharing image render queue not the computing power.
    Thank You in advance,
    Regards
    Brian
    The VRay solution:
    http://www.spot3d.com/vray/help/150S..._rendering.htm
    The Backburner solution:
    http://www.chaosgroup.com/forums/vbu...ad.php?t=31969
    Ben Steinert
    pb2ae.com
      Thank You very much, that did the trick
      Especially the v-ray solution, due fact backburner can divide only frames among machines, but v-ray distributes the frame itself among the cores.
