Holy shit! Image Modeller 2009, Realviz Matchmover AND Mudbox (6 month trial but still) included in 3ds Max subscription!!! Am I dreaming? Has Autodesk gone loopy?
Subscription madness!!!
Ahh, we got a call a month back from AD making sure we knew about the subscription center. Guess I'll go check that out now! They must be trying to add value to subscriptions out of fear that beleagered companies will opt to stop their subscriptions this year.ShaunDon
Originally posted by ShaunDon View PostAhh, we got a call a month back from AD making sure we knew about the subscription center. Guess I'll go check that out now! They must be trying to add value to subscriptions out of fear that beleagered companies will opt to stop their subscriptions this year.chris
www.arc-media.co.uk
I've only tested Matchmover a little bit, but it seems pretty solid. Not sure if it's better then syntheyes which I've been using before though, I'll do some tests later I guess. One difference I've noticed is that Matchmover supports motion capture by using two synchronized cameras. Looks pretty cool.... gonna have to try it out sometime.
Is this the full license (standalone) of matchmover or is it like the plugin that was released awhile back for MAX?
I'm happy about the Imagemodeler...good addition. We'll see if matchmover is better then Syntheyes. I wonder if there will be some kind of discount offer at the end of the trial for Mudbox.-----Dwayne D. Ellis-----
Originally posted by instinct View PostSyntheyes supports multiple cams as well, just like it also supports facial or fullbody mocap using multiple cameras.
Regards,
Thorsten
@dellis: It's the full program, not the plugin.
There is no Tut, but it's in the manual under "Motion Capture" if i recall right.
Here's a nice trick for doing it with one cam
http://www.ssontech.com/phpBB2/viewt...motion+capture
Can you use Matchmover to do automatic camera matching to still shots, or is it just for multiple camera motion tracking? Just curious if it will speed up my camera-mapping type work for blending into stills.
I d-loaded Matchmover to check, but I'm not seeing anything in the help files to indicate.
Anyone know offhand?
From a brief glance it almost looks like ImageModeler would be better for it in any case.... So many things to explore, so little time.
b
