Can I power ON renderfarm via LAN?
  • Can I power ON renderfarm via LAN?
    Hi all
    OK we all know it is pretty easy to shut down the renderfarm via a small script. I want to do it in reverse as in when I shut down the farm overnight, I also switch of the electricity via the DB board. Then the next morning I only want to switch on the DB board, and power on the farm via LAN. How can I do this? It seems there must be a way as most mobo's come with a setting in the bios relating to LAN and wake.
    Kind Regards,
    Morne
    hello
    well, I use IXOR's REFAMO and it works great!
    there are alos free software to switch on computers over LAN. e.g. http://www.f-grubert.de/pwrswtch/index.htm
    unfortunately it's in german.
    best regards
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
      I use REFAMO as well. I've tried everything and this is the only on that works perfectly.
        REFAMO Rocks .....
        Natty
        http://www.rendertime.co.uk
          http://www.oette.info/
          I'm using the classic here, works great an is free.
          This signature is only a temporary solution
