tga in combustion
  • tga in combustion
    I have recently been playing with combustion 4. I discovered that when you go to use the particles in the package you can't use a tga file. even if I turn it into another type of file in photoshop it still reads incorrectly. Is there no way to correct the file? Or do I just have to re-render everything?
    thanks
    val valgardson
    http://www.photorealistic-rendering.com/
    it doesn't have anything to do with the file type it has to do with the image size. if you make a 720*486 image it works fine if you make a 1280*720 image it's a mess. I rendered out an image in blender and brought it into combustion with the same problem so it's a combustion particle problem.
    val valgardson
      If anyone cares. to somewhat fix this It has to do with turning off use software opengl in preferences.
      val valgardson
