Anyone know of a script that will remove the colorcorrect script from all scene mats? Until that plugin gets fixed, we've had to stop using it, but its wreaking havoc with out model library.
Remove Color Correct from scene mats.
Agreed, running into the same, but haven't had a chance to make/find anything yet!Dave Buchhofer. // Vsaiwrk
maybe I've had my head in a cloud - whats the problem with colour correct?chris
www.arc-media.co.uk
oh right didnt know that. We are currently using it with max2009, is there any issues with that version I dont know about?
cheerschris
www.arc-media.co.uk
Not sure if it'll behave for ya but try this:
Code:macroScript ColourCorrect category:"John O'Connell Tools" ( /* This script is provded as is and is in no way to be considered a bug free utility. Any loss of time or information as a result of using this script is not the responsibility of John O'Connell so use it at your own risk! To be done: 1. Add in support for the vray override and light materials 2. Make function based cos it's smarter 3. Maybe look at adding in an averaging function for materials The latest version of this should always be available in the stuff section of http://www.joconnell.com so check back often */ Rollout ColourCorrect "Learn to spell colour properly!" ( -- Begin Rollout Spinner cc_gamma "Colour Correct gamma" type:#float align:#right range:[0.0,10.0, 2.2] button applyCC "Apply Colour Correct" width:200 align:#right button removeCC "Remove Colour Correct" width:200 align:#right on applyCC pressed do ( temp_sel = selection as array for i = 1 to temp_sel.count do ( if temp_sel[i].material != undefined then -- If the object doesnt have a multi sub mat material ( mat_subs = getNumSubMtls temp_sel[i].material if mat_subs == 0 then ( temp_mat = temp_sel[i].material if (classof temp_mat == VRayMtl) then ( if (classof temp_mat.texmap_diffuse != ColorCorrect) then ( diffuse_tex = temp_mat.texmap_diffuse diffuse_colour = temp_mat.diffuse cc = ColorCorrect() temp_mat.texmap_diffuse = copy cc temp_mat.texmap_diffuse.src_tex = diffuse_tex temp_mat.texmap_diffuse.gamma = cc_gamma.value temp_mat.texmap_diffuse.src_color = diffuse_colour ) else ( temp_mat.texmap_diffuse.gamma = cc_gamma.value ) ) else ( if (classof temp_mat.diffuseMap != ColorCorrect) then ( diffuse_tex = temp_mat.diffuseMap diffuse_colour = temp_mat.diffuse cc = ColorCorrect () temp_mat.diffuseMap = copy cc temp_mat.diffuseMap.src_tex = diffuse_tex temp_mat.diffuseMap.src_color = diffuse_colour temp_mat.diffuseMap.gamma = cc_gamma.value ) else ( temp_mat.diffuseMap.gamma = cc_gamma.value ) ) ) else ( -- If the object has a multi sub mat material for m = 1 to mat_subs do ( temp_mat = temp_sel[i].material.materialList[m] if (classof temp_mat == VRayMtl) then ( if (classof temp_mat.texmap_diffuse != ColorCorrect) then ( diffuse_tex = temp_mat.texmap_diffuse diffuse_colour = temp_mat.diffuse cc = ColorCorrect () temp_mat.texmap_diffuse = copy cc temp_mat.texmap_diffuse.src_tex = diffuse_tex temp_mat.texmap_diffuse.src_color = diffuse_colour temp_mat.texmap_diffuse.gamma = cc_gamma.value ) else ( temp_mat.texmap_diffuse.gamma = cc_gamma.value ) ) else ( if (classof temp_mat.diffuseMap != ColorCorrect) then ( diffuse_tex = temp_mat.diffuseMap diffuse_colour = temp_mat.diffuse cc = ColorCorrect () temp_mat.diffuseMap = copy cc temp_mat.diffuseMap.src_tex = diffuse_tex temp_mat.diffuseMap.src_color = diffuse_colour temp_mat.diffuseMap.gamma = cc_gamma.value ) else ( temp_mat.diffuseMap.gamma = cc_gamma.value ) ) ) ) -- end else ) ) ) on removeCC pressed do ( temp_sel = selection as array for i = 1 to temp_sel.count do ( if temp_sel[i].material != undefined then -- If the object doesnt have a multi sub mat material ( mat_subs = getNumSubMtls temp_sel[i].material if mat_subs == 0 then ( temp_mat = temp_sel[i].material if (classof temp_mat == VRayMtl) then ( if (classof temp_mat.texmap_diffuse == ColorCorrect) then ( if (temp_mat.texmap_diffuse.src_color != (color 255 0 0)) then ( temp_mat.diffuse = temp_mat.texmap_diffuse.src_color ) temp_mat.texmap_diffuse = temp_mat.texmap_diffuse.src_tex ) ) else ( if (classof temp_mat.diffuseMap == ColorCorrect) then ( if (temp_mat.diffuseMap.src_color != (color 255 0 0)) then ( temp_mat.diffuse = temp_mat.diffuseMap.src_color ) temp_mat.diffuseMap = temp_mat.diffuseMap.src_tex ) ) ) else ( -- If the object has a multi sub mat material for m = 1 to mat_subs do ( temp_mat = temp_sel[i].material.materialList[m] if (classof temp_mat == VRayMtl) then ( if (classof temp_mat.texmap_diffuse == ColorCorrect) then ( temp_mat.diffuse = temp_mat.texmap_diffuse.src_color temp_mat.texmap_diffuse = temp_mat.texmap_diffuse.src_tex ) ) else ( if (classof temp_mat.diffuseMap == ColorCorrect) then ( temp_mat.diffuse = temp_mat.diffuseMap.src_color temp_mat.diffuseMap = temp_mat.diffuseMap.src_tex ) ) ) ) -- end else ) ) ) ) CreateDialog ColourCorrect width:300 )
color correct
Yep... I had to uninstall it too.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- ​Windows 11 Pro
I've been working on a conversion script, give it a try:
Code:/* CC converter - V0.1 Conversion tool betwen Cuneyt Ozdas "ColorCorrect" plugin and 3DSMax native "Color Correction" plugin. Use it at your own risk Script by Enric Saumell */ roll_cc_converter try(destroyDialog roll_cc_converter)catch() rollout roll_cc_converter "CC converter" ( button btn_cc_to_ccn "ColorCorrect to Color Correction" button btn_ccn_to_cc "Color Correction to ColorCorrect" checkbox chk_only_selected "Only Material Editor selection" checked:false fn cc_to_ccn only_sel = ( if (only_sel) then ( cc_instances = getClassInstances ColorCorrect target:MeditMaterials[activeMeditSlot] ) else cc_instances = getClassInstances ColorCorrect for cc_map in cc_instances do ( ccn_map = Color_Correction() ccn_map.name = cc_map.name ccn_map.color = cc_map.src_color ccn_map.map = cc_map.src_tex ccn_map.lightnessMode = 1 ccn_map.gammaRGB = 1.0 / cc_map.gamma ccn_map.hueShift = 0.0 if cc_map.hsl_on do ccn_map.hueShift += (mod (cc_map.hsl_hue_off + cc_map.hsl_hue_gain + 180.0) 360.0) - 180.0 if cc_map.hsv_on do ccn_map.hueShift += (mod (cc_map.hsv_hue_off + cc_map.hsv_hue_gain + 180.0) 360.0) - 180.0 replaceInstances cc_map ccn_map ) ) fn ccn_to_cc only_sel = ( if (only_sel) then ( ccn_instances = getClassInstances Color_Correction target:MeditMaterials[activeMeditSlot ] ) else ccn_instances = getClassInstances Color_Correction for ccn_map in ccn_instances do ( cc_map = ColorCorrect() cc_map.src_color = ccn_map.color cc_map.src_tex = ccn_map.map cc_map.name = ccn_map.name cc_map.gamma = 1.0 / ccn_map.gammaRGB replaceInstances ccn_map cc_map if (not close_enough ccn_map.hueShift 0.0 10) do ( cc_map.hsl_on = true cc_map.hsl_hue_off = ccn_map.hueShift ) ) ) on btn_cc_to_ccn pressed do cc_to_ccn chk_only_selected.checked on btn_ccn_to_cc pressed do ccn_to_cc chk_only_selected.checked ) CreateDialog roll_cc_converter width:200 height:80 pos:(point2 10 120)
Notice it only converts the following parameters:
- Color
- Texture (e.g. used bitmap)
- Gamma
- and Hue
Still havent found a good way to translate the rest of ColorCorrect parameters, it has a lot more options than MAX Color Correction, and those that are in both don't behave the same way. If someone finds a way to translate them feel free to enhance the script (but please tell me how you've done it)
As far as I know, there is no way to retrieve information from a missing plugin through MaxScript, so you need to have ColorCorrect plugin installed in a machine to use it. I guess that, at most, I could write a script to blindly replace missing map plugins with something else, but you would lose all the plugin data.
Originally posted by percydaman View PostDoesn't look like it works. I'm guessing you have to have the script installed to have it find the script and remove it. Also doesn't appear to work in blends? Not sure on that one.
