Light Source Detection
  • Light Source Detection
    This might just be my imagination - but wasn't there a script which detected the approximate location of a light source?
    For example, if I have a HDR in a scene and there's one main light source which is the sun - is there some way through a script to automatically insert a Vray Sphere or key light by detecting the brightest value and positioning it in relations to the 0,0,0 world coordinates?
    LunarStudio Architectural Renderings
    HDRSource HDR & sIBL Libraries
    Lunarlog - LunarStudio and HDRSource Blog
    If i recall right the SiblEdit could do that. In addition you can generate lightsources using median cut algorithms with hdrshop + lightgen
    Regards,
    Thorsten
      Yeah I'm trying to figure out a way without having to use sIBL.
        I usually make object fully reflective and then position dummy light with the "Place Highlight" command. Sometimes I just use a sphere innstead of object to easier spot the sun in the HDRI reflection
        Hope this helps
        Zoran
          Really good tip! Thanks a lot!
          Lasse Kilpia
          VFX Artist
          Post Control Helsinki
