Originally posted by glorybound
View Post
Interactive 3D Architecture Vizualization
Kind Regards,
Richard Birket
http://www.blinkimage.com
SmoothMove does ring a bellBobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- ​Windows 11 Pro
Originally posted by dbuchhofer View PostTheres nothing really that you cant do with quest/unity/virtools/<insert package here>, its all about the effort required to get to a certain level of quality, and the publishing.
As a 6-7 year user of virtools, I'd lean towards unity, because of its great publishing and its large helpful community.
prepping for realtime work requires a little extra knowledge/effort to get the most out of it, you want to format your meshes/materials differently if you wish to get the best out of the realtime engines, and really it means keeping your models a lot cleaner than we're used to now, somewhat along the lines of what was needed 6-7years ago for rendering.
now that we're in the land of unlimited ram and proxy objects, its progressively harder to just 'convert' a scene to realtime without a fair amount of work~
(Not that it can't be done, but it takes time, [or scripting] ! )
A few unity examples I've set up:
Link removed ~6mb, AO baked into 4 1024 lightmaps (So its noisy as hell currently), should be playable on most computers.. Realtime Glow, selectable AA settings
Link removed ~7mb, fairly slow on older systems, no baking, just ingame lighting. Realtime AO, Glow, Water.. no model cleanup from the original, thrown together as a quick test.
When you start looking into more complex stuff like realtime reflections, it can start to get a bit complex however.
Is it possible to simply 'convert' a Max model of a building into Unity 'format' and then walk around it freely, or must you master scripting etc for it to function properly?Kind Regards,
Richard Birket
Unity has prebuilt modules that you literally just drop into a scene to get a quick walkthrough mode set up, quite painless even without any scripting knowledge.
I suggest starting with a very very simple scene to figure out some of the workflow before trying anything serious though.Ben Steinert
pb2ae.com
Will give it a try.
It is a bit weird that there isn't just an option to 'export as an interactive 3d model' button in max, and then you can view it using another bit of software. A bit like a VRML output I guess but just brought bang up to date.
I don't expect the qualities of our GI renderings, but a robust 3d model even with plain colours would be a very useful tool to explore buildings and the spaces around them.Kind Regards,
Richard Birket
Hi !
I'm using Stonetrip Shiva to make 3D realtime content.
Relatively Cheap, well designed and rock solid.
The cool thing is it have a very solid webplayer, working with almost all browsers, (Pc/Mac). You can also publish .exe files, and more (psp, iphone...)
Here's some examples i made with it (max/Vray/Shiva) :
Use keyboard arrows to move and leift click to rotate.
GUi buttons are ; subjective, orbit, and fullscreen.
- interior demo :
http://solidrocks.subburb.com/index....=14&Itemid=102
- exterior demo (bigger file, lot of trees and plants)
http://solidrocks.subburb.com/index....=14&Itemid=103
I found this in the past, and they have added some form of VRay support since I last looked at it:
http://www.codeblend.com/
Seems simple enough. I would be interested to hear if anyone has any experience with this package.Ben Steinert
pb2ae.com
- interior demo :
http://solidrocks.subburb.com/index....=14&Itemid=103Kind Regards,
Richard Birket
Originally posted by beestee View PostI found this in the past, and they have added some form of VRay support since I last looked at it:
Seems simple enough. I would be interested to hear if anyone has any experience with this package.Kind Regards,
Richard Birket
Originally posted by squeakybadger View PostCodeblend lights look like nuclear hot spots
Having a good old play with ShiVa at the moment, but it likes to crash on dae export (or it doesn't export materials)
I know I had a few headaches with the install of Shiva (isn't that a type of cat food?) on an XP 64bit system with Max2009 64bit, but I got there in the end I think.Kind Regards,
Richard Birket
