need some help with a script.
  • need some help with a script.
    i've spend several hours to find a script for the following problem.
    after importing 3ds files from cad software i've end up with many meshes with isolated vertices.
    one script i've found can fix this for only one mesh in single selection.
    macroscript RemoveIsolatedVertices category:"- SelfMade -"
    on isEnabled return
    selection.count == 1 and classOf selection[1].baseobject == Editable_Mesh
    on execute do
    max modify mode
    modPanel.setCurrentObject $.baseobject
    meshOps.removeIsolatedVerts $
    im not able to rewrite it so it works with multiple selection.
    after import i have hundred of meshes with isolated vertices.
    can anyone please help me or is knowing a script for that case?
    thanks for any advice!
    axel
    This should do the trick:
    Code:
    macroscript RemoveIsolatedVertices2 category:"- SelfMade -"
        on execute do
            for o in selection where classof o == Editable_Mesh do meshop.deleteIsoVerts o
      hey codi!
      works perfect! and it's a very efficient and fast script. even on hundreds of objects. thanks for your help!
        You are welcome
