animation with skydomes.
  • animation with skydomes.
    I'm wanting to do an animation. A flat background is no good. So correct me if I'm doing something wrong. I create a hemisphere geosphere. copy instance and scale. Do a booleon and apply a sky texture map. Any good free skydome texture maps out there?
    1. Does the sunlight have to be inside the dome to work? If not I assume I reduce the opacity of the dome so that light gets through.
    2. Do I put the texture map in the enviroment slot or should I keep a plain blue color. I guess thats up to me
    3. oppacity decrease descreases the ability to see map?
    any other tips.
    I feel retarded asking these questions.....but if you don't ask
    a sky dome wont allow environment gi through - its not a viable solution unless you precalculate gi without it and then unhide it for the final render
    your best option is to dump a spherical sky panoramic image in the environment slot
    regards,
    mark
      why not just put your environment in your environment slot.
        if i just put the sky in the enviroment map then when the camera turns the same sky view goes with it and looks silly?
        r
          You need to change the mapping coordinates to environ and then choose spherical , instance the bitmap for more control.
          Eric Boer
          Dev
            Some suggestions I can add would be to either...
            make an HDRI of your sky/ land and use this in the environment slot or...
            use the VRayMatWrapper to contro your sky/ ground materials better and tweak the GI in this way.
            I've used both of these procedures and they have acceptable results.
            --Jon
              your sky doesnt "go" with it if its a sperically mapped environment
