HDRI creation from full frame fisheye
  • HDRI creation from full frame fisheye
    I want to create a hemispherical HDRI, using a full frame fisheye and shooting upward (in this case a sigma 8mm circular fisheye mounted on a canon 5Dmk2) . The resulting image is something similar to a mirror ball that we would have shot from above. My quetion is :
    - can we use the resulting image like this, or do we have to "unwrap" the image to another format so that it will be usable by vray ?
    Thank you for your help,
    ____________________
    WALEE / www.walee.com
    You will only have the sky but nothing under the horizon.
    The fisheye have a different projection characteristic then a mirror ball. I played around with shrink wrap projection (which is a mirror ball projection) and the tiling option, but it isn't a similar projection - you have to convert the image into a spherical projection ..with hdrshop1 or any other software.
    About exposures have a look at this : http://projects.ict.usc.edu/graphics/skyprobes/
    good luck!
    www.cgtechniques.com | http://www.hdrlabs.com - home of hdri knowledge
      thx for the link, it's a really interesting article.
        Check Peter Guthrie's blog: he has a tutorial on exactly that IIRC. Either way you can certainly create skydomes for use in Vray with that approach.
        b
        Brett Simms
        www.heavyartillery.com
        e: brett@heavyartillery.com
          yes Brett, peter gave me the url of his blog, it was pretty useful thanks.
