2011 - merged files losting bitmaps?
  • 2011 - merged files losting bitmaps?
    I have to re-render a job I did in 2010 a month ago, but for some reason the file will not open properly now. I was able to merge the contents into a new file in Max 2011, but all the bitmaps are gone. Not just broken paths, but just blank bitmap shaders etc.
    Does anyone know some trick/setting that might cause this? I have not had it happen before.
    THanks in advance
    b
    Brett Simms
    www.heavyartillery.com
    e: brett@heavyartillery.com
    perhaps using upcoming vray SP5 will fix this?
    Martin
    http://www.pixelbox.cz
      Nope; this is not related to V-Ray unfortunately.
        ill be waiting for Autodesks SP anyway...no use jumping to new MAX now....
        Martin
          some times ago it happened to me as well
          an it was simply opening a max 2010 in max 2010!!!
          all bitmaps gone, not only the path was missing but also the bitmap name so all the rebuilding process was a pain
          Alessandro
            Couple of guys here had seen this with opening old scenes in 2010.
            They were hoping an upgrade to 2011 would fix it...
              Thanks guys - guess it's just luck of the draw then
              b
              Brett Simms
                Maybe you could try merging the file on a 32bit machine in 32bit max 2011 and see if that works
                Chris Jackson
                Shiftmedia
                www.shiftmedia.sydney
