Anyone have any tips or tricks to move your current 3ds max setup (UI/scripts/etc) to a new machine or a newer version? While I can save the current UI, when I reload it in the new version a lot of stuff is broken (grayed out icons) or missing. Anything to make it a little less painful would help.
Move 3ds max config to new machine/newer version
www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.Tags: None
Moving to a new machine isn't too bad, but upgrading to a newer version pretty much sucks. I have not found a way to take my current config and apply it to an newer version. What usually tends to happen is that I overwrite the menus so any new feature is removed because my previous setup didn't have it in my menus.
Are the grayed out Icons used for controlling maxscripts or other plugin type stuff?
I will definitely be watching this thread to see if anyone has a better solution. I typically just have both versions of max open and transfer as much as I can. The rest I just update as I go, especially with the Shortcut keys. I usually don't remember all of them until I need them and they don't work! LOL.
Moving to a new machine isn't too bad, but upgrading to a newer version pretty much sucks. I have not found a way to take my current config and apply it to an newer version. What usually tends to happen is that I overwrite the menus so any new feature is removed because my previous setup didn't have it in my menus.I typically just have both versions of max open and transfer as much as I can.
Are the grayed out Icons used for controlling maxscripts or other plugin type stuff?www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
Hi dlparisi
I use many, maaany script and free plug-ing. I built myself my custom toolbar ( I hate ribbon!), quadmenu, menu and a lots of shortcut
About the script/plug, I create my folder in my hard drive with all my script in the correct installation folder (script, UI, macroscript etc...)
So, I just copy-paste this folder in the new 3ds max installation directory and all works fine. Some script need a manually installation (drag and drop in the viewport), but this scripts are in the custom folder.
About menu, quad there no fast solution. You must recreate from scratchevery 3ds max release AD add some extra menu and, if you don't want to loose thas, you must do manually.
This is the very boring part. Usually, this operation take me 1-2 working days, if all work fine. In fact, I change my 3ds max version after 6-10 month after the official release date, due to the free pluging upgrade by Dave (maxplugins.de admin)
For the shortcut, I copy-paste my old configuration
For Color, same as the shortcut.
Hope this can help you
