Modeling dilemma
  • Modeling dilemma
    Anybody got a bright idea how to model these little buggers?
    http://www.studiolilica.com/gally_pix/helices.html
    sigpic
    J. Scott Smith Visual Designs
    https://jscottsmith.com/
    http://www.linkedin.com/in/jscottsmith
    http://www.facebook.com/jssvisualdesigns
    two splines with a sweep modifier then put shell on it
      Hmmm... I'm not following. Isn't sweep mod similar to lofting - ie, one path and one section?
      sigpic
        Yes, but sweep is _much_ more robust than loft. At the bottom of the sweep mod you can create a graph for how you want the scale to be dictated as well in curves. (For these you probably want a bell-curve looking line)
        Colin Senner
          @ccs sorry, i cant help in anyway. but i like yout avatar so much. congratz. i cant stop laughing now because of thinking at the office. thx
          max 9 + vray
            i would go with a line and select loft in Compound Objects. then select your shape. At the bottom of Loft is a segment called Deformations, open that up and select Scale. A little window will open up and you can then manipulate the shape with a spline. It will do exactly what you are looking to do.
            Val
            val valgardson
            http://www.photorealistic-rendering.com/
