loft
  • loft
    How do you avoid this kind of bad geometry when using lofts?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Are the corner vertices in your path welded?
    Check out my models on 3dOcean
      yes, they are welded.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        In the surface parameters/output select Patch. It should correct the problem.
        Val
        val valgardson
        http://www.photorealistic-rendering.com/
          I always try to make sure that my path is located along the inner edge so that this exact problem doesn't happen. This will prevent wide shapes from folding into itself like your image shows. Works in most cases for me. Though in certain situation that doesn't always work.
          Troy Buckley | Technical Art Director
          Midwest Studios
            Not a solution for lofts but the sweep modifier doesn't seem to have this problem for me.
