The Rendering Killer!
  • The Rendering Killer!
    http://www.ronenbekerman.com/twinmot...er-vegetation/
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    This sure looks amazing.... But again the hardware used and the soft. limitations, no clue on that yet... But a Vegetal render at 0.012 sec sounds nice.
    Alain Blanchette
    www.pixistudio.com
      What is it about this that looks amazing? Did you play, for example, Elder Scrolls IV: Oblivion when it came out? In 2006? Because that's more or less what I see.
      Ville Kiuru
      www.flavors.me/vkiuru
        Ya but if it is a straight plug in for max, and it can render out an animation in real time , then is going to change the work flow of test renders and end images.
        Again if it is a striaght plug in and does not cost the earth, playing a game is one thing not having the bake every thing and optimize everything will be a major change.
        Phil
          The success of something like this depends greatly on three things:
          1. Ease of use.
          2. Price.
          3. Quality.
          I think the quality of what has been shown is sufficient as long as the other two are acceptable as well.
          Ben Steinert
          pb2ae.com
            To be honest it looks much more like a standalone app built around a game engine running the viewport to me!
            Could be wrong of course.
            Regards
            Bri
            Check out Lynda.coms Vray Courses
              Regards
              Bri
              Yes it does , they say it works with Max, but unless it works within max as a plugin like Vray which I doubt, it may not fly.
              I worked with Formz and a lot other packages over the years and that used to add a degree of difficulty for me, and why I moved to Max in the end.
              One stop shop.
              phil
                Quote taken from a reply to one of the 'Comments'
                >ka-ra
                >It’s all modelled in 3DSmax and imported in Twinmotion2!
                If the Export from Max and Import into the App works well then I think there will
                be a LOT of uses for this App!
                Regards
                Bri
                  Looks like they are up and running now..
                  http://www.twinmotion.com/
                  Alain Blanchette
                  www.pixistudio.com
                    Expensive...but may be worth it since it seems very easy to use. I just finished watching the Revit import tutorial video that they put up, and it seems clear that they have autodesk beat at their own game on importing the fbx format. That alone may be market enough for a tool like this.
                    They also tout the ability to compile the scenes as standalone executables, which has some added value as well.
                    Still, that is a lot to wager on a relatively new software developer when the industry is understandably so cautious with spending.
                    Lumion looks to be a similar tool that is in development from the makers of quest3d. It looks promising as well, so maybe there is a little competition in this market.
                    Ben Steinert
                    pb2ae.com
                      I've got a high-end system w/ 12gigs of ram and a 480gtx. I installed the trial, played w/ it for two solid days and it's awesome...when it works. Currently, it seems bug-ridden and doesn't work reliably, as should be partially expected w/ most new releases. What is NOT expected is the outrageous cost for buggy software with the practically mandatory subscription for bug-fixes/updates.
                        I installed it, played with it after a few crashes, uninstalled it
                          My spam blocker blocked the site so I didn't go any further. I was curious to see if it was a game changer.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Originally posted by retardus View Post
                            ...What is NOT expected is the outrageous cost for buggy software with the practically mandatory subscription for bug-fixes/updates.
                            Reminds me of an experience I had some few years ago with a company from Madrid...I promised myself I would never fall again for a nice package before I saw the contents !
                            • #15
                              kind of like getting married!
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
