3dsmax instance still runs after 3dsmax quit
  • 3dsmax instance still runs after 3dsmax quit
    Anyone else experiencing this. Sometimes I can have about 4 instances of max open in the task manager when Ive only been using one.
    Regards
    Steve
    My Portfolio
    Which 3ds Max version?
      you have the ColorCorrect plugin installed?
      Marc Lorenz
      ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
      www.marclorenz.com
      www.facebook.com/marclorenzvisualization
        3dsmax 2010..not sure about 2011 as I havent had time to use it that much.
        Regards
        Steve
        My Portfolio
          Yes I do have the colorcorrect plugin installed....is it something I have to live with if I use that ?
          Regards
          Steve
          My Portfolio
            It's a known issue with the CC plugin in 2010+. It's a beta since ages and has never been updated.
            I use a small .bat file with the following contents (Beware tho! Executing this file will kill each and every
            3dsmax process!!)
            Code:
            taskkill /im 3dsmax.exe /f
              Don't know if it was here or @ CGTalk, but someone posted a startup script that will automatically kill 3DSmax when it shuts down to avoid this problem:
              kill_max_colorcorr.zip
              Close Max and Unzip the file inside "..\Scripts\Startup\"
