objects along edge/path align to object normals
  • objects along edge/path align to object normals
    Is there a way to do this ? I thought max 2011 could do it but i cant seem to work out how to.
    I basically have a path created (or I could use the edge mode in poly edit) and need an object to be repeated along this edge/path so that the normals of this object align to the faces of the object that has the edge selected.
    Any help is would be really appreciated
    Regards
    Steve
    My Portfolio
    On a spline:
    Tools - Align - spacing tools, in there, you have the follow tickbox, and the repeated objects will be oriented on this path.
    Alain Blanchette
    www.pixistudio.com
      Yeah, I knew about that but the objects dont align to the normals of an object. There is quite a lot of manual rotation involved if you need the object perpedicular to the main object face.
      Regards
      Steve
      My Portfolio
