invisible cameras and lights
  • invisible cameras and lights
    I'm sure it's just a toggle somewhere, but I have managed to run off all viewport visibility for cameras and lights. They are 'visible' in the layers palette and are selectable, but I can't see them except for their gizmo when selected.
    I've looked and googled but can't figure it out. Anyone know what to turn off/on?
    Thanks!
    b
    Brett Simms
    www.heavyartillery.com
    e: brett@heavyartillery.com
    Right click > Object paremeter > Untick Display as box ?
    Alternative viewport clipping uder second menu in left upper viewport corner...
    F3 ?
      Thanks, but that isn't it. Viewport clipping is off, and the objects are not set to display as box. It happens across all standard lights, all cameras, and in all my current files. I think its a Max setting thing somewhere....
      b
      Brett Simms
        Humh
        Restart
        Reinstall
        Format C://
        Kick
        Window...
        Move to second monitor might be display/driver issue..
          I'm sure you've tried this, but do you have them hidden by category? Look under the Display tab. It shouldn't transfer the settings to other files though, so it's certainly strange behaviour.
          MDI Digital
          moonjam
            I checked that tab and it's all in order - nothing is hidden. Very odd. I can see the target line for Vray Cameras, but no camera. Same with lights. The only light I can actually see is the VrayLight when set to rectangle mode - the rest are only visible as gizmos when they are selected. I have tried everything I can think of - it's odd. Checked 32bit 2011 though, and it is still showing them fine so I don't think it's a display driver issue, but who knows?
            Very annoying.
            b
            Brett Simms
              I am sure you already know this but anyway:
              shift + C ............toggle for camera visibility
              shift + L .............toggle for light visibility
              for my blog and tutorials:
              www.alfasmyrna.com
                Just tried that too - didn't help either It makes the camera and light target lines invisible, as well as the camera/lights themselves, but no joy on getting the objects to show. Weird. Hate to have to reinstall Max and all the plugins/scripts, but looks like I might have to try that to fix it.
                Thanks for the pointer in any case
                Brett Simms
                  Have you tried deleting the 3dsmax.ini file? When you launch max it will recreate the file based on the defaults...it may help.
                  Troy Buckley | Technical Art Director
                  Midwest Studios
                    I haven't tried that - but in searching I can't seem to find that file for 2011. I have one for 2008/2009/2010, but not for 2011. Is it called something different in the newer version, or located somewhere funky?
                    Thanks!
                    b
                    Brett Simms
                      C:\Users\[your_user_name]\AppData\Local\Autodesk\3dsmax\2011 - 64bit\enu
                      Should be buried in there.
                      EDIT: That is for Vista/win7 installation, you would need go to the appropriate location in XP, which I don't have in front of me at the moment. Sorry.
                      Midwest Studios
                        Yes! that did it. Thanks very much. Not sure why that file didn't show up in my desktop search - thanks for the extra pointer
                        b
                        Brett Simms
                          Did you happen to save the file somewhere else? We could then do a file compare and figure out what setting in there got messed up.
                          Midwest Studios
                            I did save it - attached the old one and the new one in the zip. Thanks again
                            b
                            max_ini.zip
                            Brett Simms
                            • #15
                              What happens when you create a new camera? Are they created invisible too?
                              Maybe it can be a corruption in your file. If new cameras are visible, you can try create new light and cameras and align with the old ones and delete the old ones.
                              www.alfasmyrna.com
