Using lens blur node in Autodesk Composite
  • Using lens blur node in Autodesk Composite
    Hi guys,
    trying to make use of the lens blur nod ein Autodesk Composite, but i cant make it work.
    i am connecting the RGB pass of the EXR to the input of lens blur and zdepth pass to the modulation node of the lens blur but nothing really happens...when i blur the image using the lens blur controls, its simply blurs the whole thing...how do i control which parts it blurs etc???
    can anyone please print screen the proper connection of the nodes for me?
    Thansk a lot
    Best Regards
    Martin
    http://www.pixelbox.cz
    Try the radius settings in the modulation-tab of the lens blur node.
    If you want your sharp zone somewhere in the middle of your zdepth range you'd have the remap it in a way.
    www.hofer-krol.de
    Visualization | Animation | Compositing
      yep gave that a go and it works but its strange as one would believe that the focus aned everything happens in the main tab of the lens blur.
      i also find its bluring capabilities somewhat weird looking compared to PS, lensblur, DofPRO...if only AE was node based or NUKE was less expensive )))
      Martin
