"RPC 3.0 Plug-in for 3ds Max 2011" compatibility issues
  • "RPC 3.0 Plug-in for 3ds Max 2011" compatibility issues
    Has anyone there tried the new “RPC 3.0 Plug-in for 3ds Max 2011” from Archvision? Does it now work properly with Vray and does it work well in animations?
    I am referring to animations with camera movement only.
    Also, what sort of landscape entourages do you use in case of an exterior animation?
    PLEASE ADVICE.
    Thanks in advance.
    works fine here
    only have 2 problems with it. 360 degree spherical views the rpc doesn't render. For any other renders the reflection doesn't work correct. In the reflection you see the same as the actual rpc (instead of the bacl of the rpc - when standing in front of mirror)
    otherwise seems fine
    (this thread is for POSTING TIPS and TRICKS - not for requesting them)
    Kind Regards,
    Morne
