random uvxform offset for multiple objects
  • random uvxform offset for multiple objects
    Hi there,
    Im a big maxscript novice and so im having a few problems with getting a simple "randomize UVWXform" script to work.
    It seems to work. I have to make the uvwXform mods unique before pressing button 2, and the offsets all seem to randomize when looking at the mod, but visually it doesnt update. Not sure what is going on to be honest.
    You have to select your objects first and then button 1 applies a uvw_xform mod to each.
    Any ideas ?
    Here is the code so far(taken from another code but altered for uvwXform):
    Code:
    rollout t "Test"
    	local mymod = (uvw_Xform())
    	button b "Create UVWMap"
    	button b2 "Random Offset"
    	on b pressed do
    	modPanel.addModToSelection (UVW_Xform ()) ui:on
    	on b2 pressed do
    		for i = 1 to selection.count do
    			obj = selection[i].modifiers[#UVW_Xform]
    			obj.U_Offset = random 1 500
    			obj.V_Offset = random 1 500
    createdialog t
    Regards
    Steve
    My Portfolio
    Dont worry. I worked it out. I need to add the decimal points to the random numbers otherwise they remained integer.
    Here is the code if anyone is interested.
    Code:
    rollout t "Test"
    	local mymod = (UVWMap())
    	on b pressed do
    	on b2 pressed do
    			selection[i].modifiers[#UVW_Xform].U_Offset = random 1.0 2.0
    			selection[i].modifiers[#UVW_Xform].V_Offset = random 1.0 2.0
    			selection[i].modifiers[#UVW_Xform].W_Offset = random 1.0 2.0
    createdialog t
    Regards
    Steve
    My Portfolio
