Pro Engineer help - How to export model from 3dsmax to Pro/E ??????
  • Pro Engineer help - How to export model from 3dsmax to Pro/E ??????
    Does anyone know how to do this. Pro/E cannot import obj...and I cannot seem to find a list of what it can import.
    Any help really appreciated as this is turning out to be a nightmare !
    Regards
    Steve
    My Portfolio
    I'm afraid I can't check right now but have you tried STL?
    MDI Digital
    moonjam
      I can't seem to export to STL or IGES. If I dont select my meshes, IGES and STL show up as an option to export but if I select them they are not in the export list. I did read that only certain types of surfaces can be exported in these formats.
      It seems that Pro/E is a big pain in the arse when it comes to importing from max.
      Regards
      Steve
      My Portfolio
        Can Pro/E import DXF or DWG ? 3d files
        Regards
        Steve
        My Portfolio
          Bah! Truth be told, I've only ever had to get stuff the other way (Pro/E -> Max). I once had to get a character model into Solidworks but the guys who needed it had no concept of polygons/meshes, they just sat spinning it round & whimpering.
          It's crap that max can't export STL selections though. Even Zbrush has an STL export.
          MDI Digital
          moonjam
            Ive got zbrush so maybe I can export directly from that. Saying that though, I just checked the blender feature list and it seems to support the Pro/E format. Whether thats just export I dont know...could be a life saver !!
            Regards
            Steve
            My Portfolio
              I can't check as we don't have Pro/E ourselves but Google does show a lot of DXF/DWG importers.
              MDI Digital
              moonjam
                Well, I cannot find the zbrush STL export. Not on my list, unless of course its an additional plugin. Blender can only import PRO/E which is of no use at all to me. Ive tried exporting from max as a DXF and it just doesnt seem to work. The model I have is very complex and the dxf file only ends up as a 74k file..whereas an obj export of the same file is about 1 gig.
                Regards
                Steve
                My Portfolio
                  http://www.pixologic.com/blog/2009/0...nter-exporter/
                  MDI Digital
                  moonjam
                    Thanks for that.
                    Regards
                    Steve
                    My Portfolio
                      you should be able to export your meshes as stl in max. as far as i know, pro e should be able to read dxf files too.
                        Try DEEP VIEW it's FREE...
                        I have had great sucess using this software to open CAD files that would continuously crash every other software I tried. It is probably the best file conversion software out there... it's stable & works well
                        You need to download the Right Hemisphere [same company & also free] 3DS MAX Impoter/expoter to export out as a Right hemisphere file format
                        The DEEP VIEW stand alone can then open theright hemisphere file format & convert this to any of the formats below
                        http://www.righthemisphere.com/suppo...le_Formats.pdf
                        Hope this helps
                          Ive downloaded deep view. I can actually import the OBJ file into deep view but it will only let me save as a RH file. I cannot find a link to the max importer/exporter...
                          Regards
                          Steve
                          My Portfolio
                            Ok, found the plugin !
                            Regards
                            Steve
                            My Portfolio
                            • #15
                              Am I going mad...I can't seem to export anything from deep view..
                              Regards
                              Steve
                              My Portfolio
